1 - 9 of 9 Posts
The air screw has decided to wind itself out when I'm riding!
Had to screw it back in three times today, totally f**ked the day up!
Need some suggestions to stop it happening please( I have my own idea but need the resident gurus to confirm it)
200 xc
Cheeeers
Is it because you have a too rich idle jet in and are running it more that 2 turns out?
Are the washer and o ring in place?
If everything else is ok, stretch the spring a bit.
1 to 1 1/2 turns out runs sweet as a nut.
It's getting a fresh piston in this week so it looks like its getting a carb rebuild as well
Do you think a new o ring and stretch the spring will cure it?
A dab of Loctite and its job done
Should stay put without loctite.
Wont break the bank if you buy all three parts
54531615000 SPRING FOR ADJUSTMENT SCREW £1.56
54831071000 WASHER ADJUSTING SCREW £1.26
54831072000 O-RING ADJUSTING SCREW £1.26
so £4.08 less 15% plus P&P
Discussion Starter · #9 ·
Cheers Kev
Stripped it out and the spring has appeared to have work hardened itself nearly fully compressed!
Phone call to Jacko in the morning then!
1 - 9 of 9 Posts
