I've got alot of travel on my front brake lever I've bleed the brake and pushed the piston's right back and the adjuster still has to be at it's max for the brake to to start working at about half way pulled any info please anyone
Turn the handle bars to the left and tie the front brake lever on , leave over night and see if that improves it.
[email protected]! You were probably lucky you didn't
pop the pistons right out!
Are you using the right fluid? Is your hose ok? It hasn't been
nicked or bent causing a crack? Youmight not notice it.
