Having a bit of a problem with my TE250s (same as an exc etc) front brake in that every now and again (often it seems after a descent or climb) I have bugger all front brake with the lever then coming right back to the bars :frown:. I did recently bleed / top up the system but at Cowm this w'end it went again so tonight I plan bleed the system / change the fluid using a syringe to push fresh fluid (and hopefully any air) up through the system. How much fluid does the whole set up (caliper,line and master cylinder) hold just so I know how big a syringe I need to use?
EDIT, ACTUALLY GUYS DON'T WORRY I'VE FOUND A 100ML FELLA THAT I'M SURE WILL HOLD MORE THAN ENOUGH
