1 - 10 of 10 Posts
Hi All,
Having trouble removing the front sprocket on my 250 EXC-F. Need to remove it to get the chain slider protector off as theres a tone of shite behind it. Couple of questions...
Is it best to undo the nut with the chain on?
Is the thread conventional or right handed?
Nick:D
Right handed thread. Stick a bar through the rear sprocket and the sprocket bolt will come straight off.
Use blue loctite on the bolt when you reassemble 60Nm
But the muck should come out with a jetwash?
Or Sit on it Brakes on and get a Mate to undo it for you ,I use son number 3!!
All sorted, Got the wife to sit on it with her miss whiplash out fit on...the shed will never be the same again LOL.
Nick
miss whiplash outfit?
Pictures? ........... the forum rules state if no pictures, it didn't happen ;)
You could always do a re-construction :D
1 - 10 of 10 Posts
