Hello all I have just finished some restoration on my 125 Duke. I had to then guide it down some stairs out of my flat and I may have caught the gear shift lever on one of the stairs.
Now when I try to change into a gear nothing happens it's stuck in neutral. The pedal is very stiff and won't spring back. :frown:
Is it hitting the frame or cover
The gear shift lever isn't hitting the frame or cover, it seems to be in good shape. Is it likely to be a broken shift shaft?
Discussion Starter #5 (Edited)
