1 - 20 of 36 Posts
Thinking of purchasing the Bodis decat for the GT. does anyone have a guide on how to do it and remove the exhaust valves etc? The Bodis comes with mechanical bungs for the sensors so it doesn’t throw a fault. Tried YouTube. Thanks.
Are you set on a Bodis? I have an Arrow decat link pipe for sale c/w Healtech ESE and O2 sensor delete kit
No flat spot on mine... simple install... just dropped the collector box of complete with cables and fitted a dongle its as simple as that.
33877
Does the reservoir mount straight on the frame? I've fitted the dongle but not removed any of the gubbins.
Yes did the o2 delete at the same time, still waiting for someone on here to sell a PC off either a GT or SDR....cuz that’s the only way to do a proper job.
P3 Tuning in Liverpool do a post in service for an ECU flash, they have done so many now that can offer a tune that matches your exhaust intake configuration. You can go in and have it further tweeked on their Dyno.
When I can get home mine is going in to them as I have a full Rotweiller intake, with PCV and ignition module to be fitted, but I might just try the base flash first as I believe they can alter the throttle response and activate the blipper on the Gen 1 GT
(y) oh and reservoir relocated just using a little spacer on a bolt to avoid the subframe obstructing the lid
33898
It is plug and play but on the GT (unlike the SDR from what I hear) you need to lift the tank as one connector is buried in wires by the tank bolts. I tried from underneath but there simply wasn't enough slack. You can then decide whether to leave the probes in (but they'll get carbonised) or remove them entirely and put in the blanking bolts.
I can't recall whether the dongle is but it's in here. I think it's the lighter connector towards the right under those earth straps.
33899
1 - 20 of 36 Posts
