GT85 alternative (5 litres)
2 reading
9K views 140 replies 19 participants last post by  bigkuri
I normally buy WD40 5 litres at a time but it's got very expensive so I'm looking for an alternative.
Of the many available, Smith & Allen do something similar looking, as do Westway oils (links below).
But while searching I came across a potion that might just be a bulk GT85 alternative - Pocket Rocket Lubricant. :)
Aerosol Pocket Rocket Lubricant Repellent 5 litre
Pocket Rocket is a high specification penetrating moisture repellent. The special blend of water dispersing agents and corrosion inhibitors instantly displaces water, leaving a light 'Silicone Free' protective lubricating film.
The advanced formula containing PTFE lubricates moving parts such as hinges, wheels, chains and gears. It penetrates through dust, dirt and rust, enabling corrosion locked parts such as nuts and bolts to be released. It is ideally suited for both industrial and domestic applications and protects against corrosion.
Pack: 5 Litre container.
Supplied with free sprayer.
(£30 delivered)
Has anyone tried this stuff?
The WD40 alternatives
(£22 delivered)
(£24 delivered)
#4 ·
I have tried pocket rocket and dw40 in the past and have stuck with gt85 for bike stuff as its just better all round. ....... never had a ktm fastener go rusty using gt85.
If memory serves, pocket rocket smells really unpleasant.
As an alternative to gt85 l'll use morris md4 - same qualities as gt85, just heavier, like duck oil.
400ml is the general size for gt85, but they do do the larger ones sometimes.
#8 ·
I'm going to have to have a think about why I even buy WD40 anyway...
I use ACF-50 for protection, and various oils & greases for lubrication.
I think the main thing I use WD40 for is cleaning/degreasing, for my chain & rear wheel, and occasionally to remove any glue left by labels or wheel weights.
The principle ingredient of WD40 is Kerosene (and other Paraffin oils).
You can buy 5L of Kerosene for £18 delivered, might even be able to buy it cheaper locally.
#14 ·
Ahoy, did you know that GT85 no longer contains PTFE? And here's me just getting into it.
I assume the formula has changed.
As per GT-85 Bike Lubricant 400ml | Halfords UK
Removal of PTFE
As of January 2024, this product will no longer contain Teflon (PTFE). The product performance remains the same. Older stock will still contain Teflon and this is marked by the "with PTFE" badge on the front of the product.
#17 ·
I don't think I've ever bought any, and I'll probably not replace my WD40 either when that runs out.
I clean my rear wheel after most rides so I just need something for that. I have a strong water based degreaser for around the front sprocket area (which works great) but I'm cautious about using that on those lovely anodized rims. I prefer to use an oil based solvent there instead.
#21 ·
Works well on my bikes IRL. My 9 year old 1190 has zero corrosion and has been used through several winters, salt and all. It's bright and shiny and looks more or less like when it was new.
But after the FS365 treatment I put it in the garage and don't leave it out in the rain. It's not like ACF50 which I put on a new GSA and then pretty much left it for 3 years until I sold it (perfect under the filthy gloop). You need to apply regularly., but a quick rinse and spray only takes 10 minutes.
#22 · (Edited)
But after the FS365 treatment I put it in the garage and don't leave it out in the rain. You need to apply regularly., but a quick rinse and spray only takes 10 minutes.
Yup, that's what I worked out and why I decided it wasn't suitable for my extremely damp garage.
Also when touring my 1190 has been left outside in the rain over night (on a few occasions now) and still looks mint thanks mainly (I think) to regular ACF50 treatments.
#23 ·
Bad news on the GT85 front - all my stock is from a bulk buy a couple of yrs back ....... l'll buy a can of the woke stuff and see if its any cop.
Oh, IME, Fluid Film/Lanoguard is stacks better than ACF50 (but l like the grease for 'lectrics)
If the new GT85 is pants, it'll be MD4.
#27 ·
Yeh, I've made several of them now.
These are the best valves I've found, though any valve can be used.
This guy shows the method pretty well.
I drill mine, if you do then be really careful when drilling the can because if you nick the straw inside, it won't work.
Also I use a blow torch to solder them in because I don't have a soldering iron that big.
#43 ·
