1 - 2 of 2 Posts
Hi. I have been offered an hid kit (8000k, h7, ballast, 55watt, double bulb). I want to know if it can be put on the 2003 ktm duke ii 640 lc4. would it have any adverse effect on the wiring or get too hot ect.
Hi Aldeanl,
I have fit a 35watt HID to 2003 640 SM. Should fit on quite easy. I used the small tool box on the right of the rear wheel to store the relay and mounted the ballast behind the right radiator, on a bracket I fabricated out of ali.
The 55 watt will pull no more current than the standard bulb, so will not damage the loam if fitted correctly. Also I had no problem passing the MOT with the bulb fitted.
The only issue I have found, is that the bulb shook it's self to pieces from the bikes vibrations, so when I refitted all the shields I used loctite on all the screws.
I can only add; a mod well worth doing as I can now clearly see where I am going even when being approached by a cage with full beam. And when on full beam myself he can see me!!
1 - 2 of 2 Posts
