21 - 27 of 27 Posts
Hi lads just reading through this post, going to order one of these zeta spacers to help lower mine.
Can you confirm if it’s the red or blue spacer I need to order for my 09 excf250 shock and is anyone in northwest near Manchester with this tool for fitting it at all, happy to drop you a few quid for the use of i bring it down to you🤗
you need the red 50mm one.
I’m in Bury, I can install it for you. PM me or you can message me here Login • Instagram or www.d99.co.uk
Measure the static sag on your bike before fitting the spacer because you will need to re-set the spring pre-load after the spacer has been fitted. (Or of course you could just go for the standard sag settings which aren't a bad starting point anyway).
Reactions: glenandem
Hi pal that’s brilliant, im only in Stockport.
I will get the part ordered and then contact you when I’ve got the shock off.
Is this the same lowering insert as the zeta one from ktech as I need to order the springs from there anyway!
cheers bud, I need to order a 70 rear spring too for my weight so fingers crossed both combined will give me enough lowering to get my feet on the ground😁
yes, that the one I use, I can get it (and any other stuff you need) ordered for you if you need as I have an account with K-Tech
I'm not sure what size yours will be I might be able to find out with abit of research,
I'm Chesterfield your more than welcome to use my tool if I'm near enough for you or I can post it to you if your happy to cover postage
Cheers bud I’ve ordered the part now and going to take it to the lad above when I get time but thanks very much for the offer pal, really do appreciate that
21 - 27 of 27 Posts
