1 - 20 of 22 Posts
Ok i have just fitted a new clutch in my lc4 and now i can not engage gear with out it stalling. any ideas on what i may have missed or miss adjusted would be greatful.:mad::mad::confused:
take the clutch cover off, is the clutch pressure cap moving when you pull the clutch in
did you pre soak the plates in oil
if you did the clutch by laying the bike on its side, as I do, then there might be air in the clutch line, you might need to bleed it out with mineral fluid
I'M LOST THEN COZ I DON'T KNOW ANYTHING ON ADJUSTING CABLE CLUTCH SORRY, fuck cap locks sorry didn't mean to shout
can you not just take up slack out of the cable till the clutch don't drag
Discussion Starter · #12 ·
ive tried the cable with slack, no slack and over tight. so im at a complete loss to what i have done. when i fitted the new clutch i made sure the steels had the sharp edges facing in, does this apply to the friction plates? do they have sharp edges??????
Iirc, I think the plate at the back of the pack is slightly larger inside diameter to fit over an o-ring? I'm on iPad so can't upload pic but hopefully you can see the different plate and o ring here:
Clutch 625 640 660 LC4 04-06
Items 9 & 17.....If ya put the wrong plate in or trap the o ring it'll stop the clutch working.....
1 - 20 of 22 Posts
