1 - 14 of 14 Posts
hi, I have a 2010 KTM 125 EXC and a problem! Just wondering if anyone can help. I was out on it last week on the road the engine stalled and the back wheel locked up i pulled the clutch in whilsed skiding down the road and the rear wheel was still locked. It wasent the rear brake binding on because the disc was cold. After letting the bike cool down i started the bike and it was fine went into gear fine and rode fine.... I defo know it wasent the brake because yesterday i put it in gear with the clutch pulled in (engine not running) and and it was doing it again the rear wheel locked when it was cold . So it does it when its hot or cold. It does it intermittently one day it will be fine the next back to locking up again! Anyone had or herd of similar problems??
Thanks Chris
Their fine It does it when i pull clutch in when its in gear and i try and start it its almost like the clutch has gone...
Do you basically mean it wont roll, in gear, engine off?
If so that is pretty normal.
How fast are you going when it locks up?
How much clutch drag should there if any? In gear with clutch in pushing the bike??
every dirt bike i ever owned has a bit of drag it would be hard push around
1 - 14 of 14 Posts
