Hi all,
After I changed the throttle cable on my 990sm I started getting 9 blinks on the orange FI light after switching ignition on . After a little digging i discovered the 9 flashes relate to the following error code -
09 - Warning lamp FI (MIL) flashes 9x short
Manifold absolute pressure sensor cylinder 1 - input signal too low
Manifold absolute pressure sensor cylinder 1 - input signal too high
I think i have located the two sensors on each manifold but they look in good condition (visually) so i'm a little stumped as what to do next?
Initially the bike would start, idle a little rough but actually ride ok (apart from low speed where it was snatchy as fcuk!). I had to take it out yesterday and after 30 miles it cut out and now wont start at all - sounded like it was starved of fuel. Do i just buy new sensors or is there anything else i can check first?
I have a TuneECU which confirmed the 9 flashes mean the above error code but no other faults were stored...??
Cheers!
Cheers!
