Sorry to ask, I have checked but can't find any answers to this so far.
I am looking at a 2016 super duke R, it has a full service history and has the akarapovic exhaust. It has 53000 km's (about 30k miles).
It smoked a little when they started it up but said that the super duke r is known to smell like it is running rich with the exhaust.
So am I looking at a recipe for disaster or an opportunity for a fun weekend toy without spending a huge amount of money and is the running rich comment accurate?
I had one with 26k on and it didn’t smoke or run rich, in fact it ran the best out if the 3 I’ve had, one from new and the other with 6k on, all with Akrapovic fitted
Thanks WazzaDuke33.
Is your 26k in miles and was the bike still generally good at that?
Thanks WazzaDuke33.
Yeah, 42km, it was perfect, like a new bike really aside from some normal and expected minor wear from use . It had been serviced annually and well looked after, valves done around 20k all in spec
1290 Superduke R
Thanks Kestrel R. Any issues other than general wear and tear?
The only problem I've had was what I thought was a clutch slave issue. Very very gradually my clutch lever goes slack. I bleed it, it's fine and gradually I start losing pressure again at the lever. It's a minor annoyance because it takes a few thousand miles to get to the point where it needs bleeding again and there are no leaks anywhere. I fitted an Oberon slave but it's still doing it so I'm assuming it's a MC issue. There is a replacement piston kit available or I might send the whole MC to Venhill for testing. They make aftermarket piston kits and can ream out and recondition MCs.
Otherwise the bike has been faultless.
