I have done 1650 miles on my 990 2012 super duke r in the 2 months since buying it but noticing it has a thirst for oil ! its doing 400 miles to 350ml of oil ! now that seems excessive to me so i took it back to the dealer i bought it from as it is under warranty and they are telling me i am OVER filling it as i am not checking the oil correctly ! in the manual it says get engine fully warmed up or after a ride and stand it up level as in a paddock stand i use, leave it for 5 mins after switching off then check the level on the clear pipe on the side of the oil tank or thats how i have been doing it and did the same on my 950 sm for the 2 years i had that aswell, dealer says NO NO NO start the engine and as long as there is oil in the clear pipe thats it plenty of oil !!! ? so they said after the engine stops oil drains into the engine so checking the oil level on the clear pipe will always show its low and when i top it up to the max mark i am over filling it ! doesnt sound right to me, they have also said there is a scavage valve/1 way valve in the oil pump somewhere and if this is not working oil will drain back into the engine when engine is turned off so they are talking about replacing that.
Im not convinced because i have put about 3lt of oil in this bike in 1600 miles and if i had over filled it by 3lt im sure i would of seen it piss out all over the place but no oil leaks anywhere, motor runs mint sounds mint and i cannot see or smell burning oil ! any thoughts more than welcome.
