1 - 10 of 10 Posts
Hi guys when i bought my bike 2 weeks ago it came with mooses already fitted, just wondering how i check if they are ok to re-use as i am about to fit a new tyre on the back cheers, jamie
If the tyre doesn't feel 'flat' then it is good to go. I tend to just ride until i can feel the front rim being smacked by the rocky terrain since the rim on the exc is dented anyways.
If you just ride boggy terrain,then a well worn mousse will work better.
Remember that what is OK for a slower rider aint OK for a faster rider.
What BLUE(UK) says, If the tyre feels way too soft with the mousse fitted it's time to change it
take tyre off. Look at mousse. If its looks knackered - it is!
If there are no big chunks missing and it not falling apart its ok. However if a front one gets too soft from use it can knock through onto the rim if you hit rocks. Time to change and keep that one for muddy race.
mousse
When its all crumbly n dry n large holes in it, even then you can wrap them with old inner tubes n tape and sling them back in, mousse lube is what you need a lot of, this stops/slows down the ware between mousse and inside tyre.have fun fitting it back on;)
I am getting two rear tyres to a moose. The tyre can slip on the rim if the moose is shot but what they said otherwise.
you need more lube use pirelle mousse lube its the best i am on my 6th tyre . tyre should not slip unless you aint got a clamp fitted
Fit a clamp,even though not recommended,just fit one.
Blimey,six tyres,I do quite a lot of road miles-France and wales this year green laning-so I was not expecting too much life out of a moose,small price to pay for no bloody punctures.
If i remember rightly,i got over 3k miles out of mine and they were still usable although i had dented the front rim a few times. I did ride a lot so they were about 2yrs old and ridden as fast as i dared(flat out on a 450exc) and monster wheelies standing up through to 5th gear etc.
1 - 10 of 10 Posts
