I lost me rebound !!
1 reading
5.6K views 11 replies 8 participants last post by  Pindie
So the bike is a 19 plate 250 EXCF (WP Xplor PDS rear shock) and as above, theres no rebound at all. Bike has 24 hours on it and no sign of oil anywhere. Does that sound like a re gas/re oil or something more serious perhaps ??
Thanks all
#10 ·
Shock apart time most likely, but do turn the adjuster all the way both ways first and test :). If the shock clunks as you bounce up and down then the main piston nut has come loose, it's good to catch this, though if you dont you'll at least have the opportunity to get a nice new Ohlins. Could also be lack of oil or air in there if the seals are gone, and the rebound shaft can freeze in place, but from your description it's not sounding like that's the case. Good luck.
