I want to put a motomaster calliper & 320mm single disc on my 950 Adv.
For the calliper to clear the spokes with a 21" wheel on, I need to space the disc and the calliper 5mm away from the spokes.
From what I understand from others that have done this, I need a spacer for the disc (could be a machined 1-piece - or could use small spacers at each bolt).
I also probably need to machine off some material from the hanger adapter (not sure how much exactly - but enough to make sure there are no clearance issues with disc, bolts, etc.
(I think I also need to relocate the speedo sensor)
Now, since I dont have a mill - or know anyone with a mill - wondering what suggestions ppl have. Is there anyone close to London that would do a bit of machining on a weekend and not charge an arm and a leg? Any members here?
Any suggestions for the disc spacer?
