Kill switch
1 reading
14K views 14 replies 5 participants last post by  exc200
Afternoon guys & happy 2021. Hopefully shape up to be better than 2020...
I had an intermittent kill switch on my 2019 300 tpi. Assumed it was the standard issue with switch not working, put the old style switch on and now my lights work again but I still can’t get my kill switch to work.
assume the switches are a straight swap? There’s a single wire that comes from the switch which as far as I know is the kill switch wire? Traced that around headstock and no breaks so I’m a bit confused as to where to go.
Cheers!
#4 ·
Hello
I have 2017 450 EXC-F and both my kill switches stopped working. I did the same as you and traced the wires to headstock. Initially every thing looked fine until I found, that indeed there was another wire that connected both kill switch wires, that had come adrift. Re-attached and both kill switches work fine now. Perhaps have another look for a 'spare' wire?
#6 ·
Just checked and found the following;
The main kill switch on the right side of handle bar has a brown wire and blue/white wire (2 wires).
The kill switch combined with the horn switch has a yellow/black wire (1 wire).
The yellow/black wire and the blue/white wire are joined together (this join was broken on mine, rendering both switches useless).
The brown wire from the main kill switch runs under the tank.
#8 ·
So it seems I have different wiring...my kill switch wire is white and grey and that is all I have, guess the 4T’s are different.
I watched avid about putting an extra kill switch in and they mentioned that if you touch the grey/white wire to frame and earth it the bike should die. Tried that and still not killing it...so should I assume a break in that wire somewhere?
#9 · (Edited)
If you are sure that the grey/white wire is the kill switch wire then find the CDI unit, try to push a bit of 'jumper lead' wire into the back of the connector where the kill wire goes into the connector, fire the engine up then dab the jumper wire to the frame, it should kill the engine. If all of that works as described then it should be easy enough to stick a multi meter on the actual grey/white wire (disconnect the CDI). Then check for continuity of the wire as it travels up to the headstock and off to the switch. You should be able to work out where the break in the wire is. Dunno about your bike but my 2013 300 had shockingly bad wiring, it has taken many hours to sort it all out and heat shrink decent insulation on the entire loom.
EDIT..Just checked my bike and the kill wire is black/yellow, of course my bike is not your bike but you do need to be 100% that you have the correct wire otherwise you could damage something expensive!
Reactions: exc200
#10 ·
Have a look where the wiring loom is clipped to the right hand side of the headstock.
The way it’s clipped causes the loom to be bent sharply when the bars are turned. I had broken wires there on my 2013 350exc. I cut and opened up the sleeving, repaired the wires and re-sleeved it with a more robust type of cable covering, clipped so it would follow a more gentle bend.
Made some progress tracing the wire back...the white/grey one connects with a bullet connector near the mapping plug, if I undo the plug, start the bike and touch the wire from the loom to the frame it kills the bike, so break is obviously between the connector and switch with the Earth being ok.
so even though the wire looks unbroken there’s obviously something not connecting, whether that’s the actual connector or a break in the wire under therubber sheath I don’t know.Job for tomorrow!
cheers guys 👍🏻
