1 - 9 of 9 Posts
Dear all,
I have a 2016 1190 in the UK which I have been doing a valve service on during lockdown. In putting it back together I have a 2 wire connector close to the upper frame tubes on the left hand side of the bike flapping around. Now I am sure it was not plugged into anything when I started....so the big question is....what does it do or could it connect to.
Pictures attached. It is a 2 wire robust connector with a wire clip. I cannot obviously see from the owners manual what it powers?
Can someone tell me.
In terms of servicing though I would certainly recommend the removal of the radiator as you probably should replace the fluid anyway and it doesn't take long.
Stay safe all.
I have the same bike so if your still struggling tomorrow I'll take the side panel off and have a look
Cav. Thanks for the offer. If you have the time that would be great. If not I will just put the radiator and petrol tank back and start it up to check all is good.
It does nothing. Possibly some attachment for an alarm system. I zip tied mine down long ago and ignore it.
And re: the radiator. I've no idea how you'd change the plugs on the front cylinder without removing it. I found the casing for the fan was cracked on mine when I last took it off, so might be worth checking if you toss yours about off-road. And you'll need to suspend the front from the ceiling when you refill the cooling system. PITA.
RubyMurray - Thanks. Will label it up and tie wrap it back.
As for the raising of the front wheel I have it mounted on a motorcycle lift and strapped it on. Not used the lift much before.
Still lockdown is relaxing so....time to ride...
When I did plugs and valve check on my 1190 I loosened and removed the rad mounts, kept the coolant in the system and just let the rad hang down supported on the rubber hoses. Worked a treat with good access, also no involved bleeding of cooling system.
Bollocks, only just remembered about this. Ive pulled the side panels off and was about to remove the tank when I got distracted and went off on another task.....
Do you still need the pics? I can pop out in an hour or so to finish.
Sorry forgot to say, the connector is just a spare. Best to tape it up to avoid a -next time -!
It's ok, the tank was coming off anyway. It just gave me the push I needed to get started on it (y)
1 - 9 of 9 Posts
