1 - 3 of 3 Posts
KTM 125SX 2003 not hitting powerband properly
soo i recently got a full engine rebuild on my ktm 125sx 2003. new crankshaft, bearings, piston, rings etc. when i broke the engine in properly and tried opening it up a bit, it wasnt hitting the powerband correctly. so then took it apart again to look at powervalve components, i ended up replacing the control arm, powervalve governor and the powervalve plate. put it back together and there was a slight improvement, but not that huge kick it should have. Thinking about taking the carb apart but i a have my doubts because its not spluttering. any suggestions would be amazing.
Thanks in advance :)
is there are 'cover' on the left hand side top of engine case ? take this off with engine running you should be able to see if power valve is open fully and at what point it starts to open
thanks for the reply.
done that today. and it moves up down, when bike is revved. sounds like a 4 stroke, very sluggish.
1 - 3 of 3 Posts
