Hi. We have moved from 125sx to a 150sx. In NZ you can not use the 250sx in MX2, reason we settled for the 150sx.
We have been racing KTM 2 strokes over 11 years and are fairly familiar with all things KTM 2 stroke.
When on the 125sx we compared a two ring piston with a one ring piston and found that the one ring piston, as result of only half the drag. responded faster when the throttle was turned on. So we always stayed with Vertex one ring pistons where we changed the ring at 20h and the piston at 40h. (We know top riders who change the piston at 12 hours...).
QUESTIONS:
1. Now I have found that Vertex does not supply one ring pistons for 150sx. And the KTM parts manuals only have 2 ring pistons also. Is this a sign that someone somewhere has figured out that when racing a 150sx at top level the difference between the two pistons is not enough to worry about?
2. Someone recommend I could buy 2 ring Vertex pistons and only use the top ring and then at 20 hour replace the ring with the 2'nd one. Do you know anyone who has done this, and if so, what were the results? I am worried re the possible build up of stuff in the empty second ring groove.
3. I have found that Woessner has a one ring piston for the 150sx. This makes me conclude that there IS an advantage in using a one ring piston in a 150sx. Am I right??
4. Any other comments re this that is worth a consideration?
Thanks in advance!
QUESTIONS:
Thanks in advance!
