Hi i had a 125 xc-w 2017 with a fmf fatty pipe from KTM Powerparts, and i have a jd jetting kit, i live in 500 meters and a temperature of 20-30 degree Celcius, had you carb settings for me please im a rookie, thanks for every help
Greetings from Jannik
I've got a 2017 125 XCW, I made a thread recently about jetting and used this setup from Al Ranger -
500 main
42.5 pilot
R8 needle jet
Stock needle clip 2
Air screw 2 and a quarter out
Hgs full pipe
I was looking for the 2018 manual to see how KTM jetted the 2018 XCW but it seems both the 2017 and 2018 are jetted poorly with the Mikuni carbs.
Another poster also recommended trying a 5.75 slide from a Yamaha 125 as the standard KTM is 4.0 so it is richer.
You could also try a different needle from Edmonson Racing. All the info I got from others is here -
http://www.ktmforum.co.uk/off-road-enduro/1284266-2018-non-tpi-ktm-125-150-xcw-manual.html
Lastly, probably the best option but also most expensive is to get a Lectron carb, setup from the dealer and very easy to use with no jets!
KTM 125 150 2017 38mm HV Lectron -spare-parts-motorcycle-online-uk
There was also an official bulletin from KTM/Husky a while back about altering the carbs on the 2017 models. I'm not 100% sure if this included the 125 but there's some info here too -
http://www.ktmforum.co.uk/off-road-enduro/1283746-2017-2t-ktm-husky-carb-official-bulletin.html
Hope that helps!
Discussion Starter · #7 ·
thanks, what is meaning with R8 needle jet, sry my englisch is so bad but in germany is the 125 xc-w very rare.
i have a 42,5 45 and a 32,5 (JD) and Mainjets 470,480,490,500,460,450 etc original and from jd, and the original needle and the needles from jd
