Hi There
I am in the process of looking to purchase a KTM250 EXC-F & am trying to work out what the obvious visual differences are from different year models.
I am looking for something in between 05-08.
I understand that an 05 bike can be registered in lets say 2007 therefor it will be advertised as an 2007
Any advise would be mush appreciated.
Ricki
250 EXC-f will on be from 2007 year bike onwards mate.
If engine number starts with 8.. its an 08
The engine number starts with model year,
then 3 digits for engine type
then 5 numbers
Frame number has VBK to start
then MXN or similar for model type
then 4 for 4 stroke or 2 for 2 stroke
then two numbers
then model year
then M
then 6 numbers that you tell a KTM dealer and he tells you the original engine number, supplying dealer, first owner, date of manufacture, date of sale etc
then 5 numbers
then two numbers
then model year
then M
if you are going to copy an old post of mine at least give me credit ;)
easiest way to tell the old 250 is the spark plug is on the right, later ones are on left
250 exc-f will on be from 2007 year bike onwards mate.
If engine number starts with 8.. Its an 08
the engine number starts with model year,
then 5 numbers
frame number has vbk to start
then mxn or similar for model type
then two numbers
then model year
then m
then 6 numbers that you tell a ktm dealer and he tells you the original engine number, supplying dealer, first owner, date of manufacture, date of sale etc
Blatently robbed off a post by his royal highness the kevinyorks !!
KTM 250 EXC-F help please
You say easiest way to tell the old 250 is the spark plug is on the right, later ones are on left
Which year was the change over please?
Ricki
Late in 2006 model year the twin cam EXCF came along. So you can find 06 250 EXCRacing (the old RFS motor) and 06 250 EXC-F (the new twin cam motor).
