1 - 13 of 13 Posts
Looks great, maybe do a little write up explaining exactly what you did ? Just noticed your split link is on the wrong way round too. Good work though !
Probably work out cheaper to get a new one ,would it ? Especially as the deals will be along soon .Still keep you busy
Little write up
Full engine rebuild
Powder coat swing arm
Swing arm guards
Rear calliper guard and cooler
Vmx wheels
Brake discs front oversized
Orange wheel spacers
6 days chain guide
Rfx rear sprocket
Front sprocket
Chain
Ktm power parts power valve cover
Ktm clutch saver
Carbon starter cover
Axp sump guard
Fmf gnarly front pipe
Fresco back box
Pro carbon exhaust guard
Air/mixture screws + oversized float bowl nut
Frame guards
Acerbis hand guards
Bling kit
Seat cover
Fork air bleeders and adjusters
Ktm grips
Pro taper bars
Titanium/nickel plated bolts (all round)
Lower fork guards
Carbon upper guards
Apico side stand
Raptor foot pegs
Hinson clutch cover
Ktm rad guards
Plastics/graphics
Tyres
Carbon tank covers
Asl rad hoses
Rfx brake + gear levers
AS3 sump bolt
Rfx kick start
Probably missed a few bits lol
That’s with out seals,bearings,pads,rim locks,shocker sock,shocker spring powder coated,I could keep going lol. 2016 only done 36 hours from new
But why......2017's are a million times better bikes and you can find them for similar money (not that you build looked short on money - how much where the ohlins?)
agreed, 2017 onwards is a good step forward.
i dont think they are ohlins, just anodized fork legs by the looks of the tops.
it certainly does look pretty though (y)
It’s only done 36 hours from new and the bike far outweighs my capabilities so for money I saw it as a newer standard bike or my bike with all the good stuff, plus I won’t see another same as mine :)
They all look the same when they are covered in shit..... and none of the 'good stuff' you've added will make the bike ride better.
Still don't see the why.
17+ would have improved your riding, they are far easier to ride fast and well, even if you're an MXer (which this bike screams of)
1 - 13 of 13 Posts
