hi looking for some help,having problems with my 2011 350sxf,today bike was very difficult to start then started but wouldnt rev kept cutting out and was spluttering,i removed and cleaned the injector,bike started 1st time ran good for few laps then started doing the same,i then fitted new injector,plug,plug cap,fresh fuel,new in tank filter and inline filter,always had a filter sock from new,im always very carefull when refuelling and confident theres no dirt in system,any help appreciated,thanks craig
Now check the fuel pump and also the relay near the rear subframe,also check the TPS calibration if the is no water ingress in connector or wiring
