Does anybody know where I can find the wheel offset details for a ktm 625 smc
I'm currently sending a set of hubs and rims for spoking and they need the wheel offset obviously with them being bare I can't measure it
ha ha............................. he said flange
Thanks kev always a big help is that both front and rear ?
And the flange of the hub with the spacer removed?
Flange on hub with no spacer.
The front is something like 9mm in from disc flange to edge of rim, I am not at home now so cant look in my book. But the rim sits central in the hub, i.e. if you put the wheel in the hub back to front the rim would still be in the centre of the forks.
Dear Kevin, I run up against the exact same problem this week. Did you had the chance to look the exact measures up in your book? I have a 2003 625 SMC. I sent you a PM. Many thanks in advance for taking time to respond.
