I have now fitted a Scott's steering damper to the bike, this is the first one I’ve had on an off-road bike and I’m really impressed with it. I rode today, did about 130 miles across the Essex lanes in very wet and muddy conditions. I was unsure how this would help in these conditions when you read about them they say a lot about rocky terrain and having the steering deflecting of rocks etc. None of that today but loads of slippery mud, ruts, more mud, and general shitty conditions. I found that the bike felt very well planted, very stable and confidence inspiring, when riding rutted lanes the bike seemed to track better in the ruts, not wandering as much as normal. I also found that a few times the front letting go a little bit and the front wanting to tuck but then not tucking and continuing, I can only assume that this was the damper helping the front stay straight.
All round the damper made the bike feel very good although the tyres, (Maxxis IT), were finding their limits toady in the wet conditions. I do like these tyres but they are lacking a bit, there’s not too much bite to them. I have a pair of Michelin Enduros to fit, I’m going to use the front for my Road Book event in 2 weeks time.
The damper can from Rally Raid, part number 031 at £396. You will also need a mount which Rally Rid will supply but with the Rade Garage rally tower kit, they supply one in the kit. The Scotts damper fitted straight on, its a very easy fitting job. The only work needed was with the silver triangular shaped mount, the pin you insert needs to rotate freely but mine was too tight. With a bit of persuasion with the Dremel, I had the pin fitting nicely.
Despite all my love for the tyres and steering damper I managed to crash the bike today on the tarmac turning into a side road. The conditions were pretty crap and the front wheel hit an iron manhole cover and just completely washed out. I was only doing about 20mph. Managed to bend the rear brake lever, mash the handguard and gouge the rear spindle nut. Apart from that a swollen little finger!
