1 - 19 of 19 Posts
Hi. I recently purchased new 790R and am looking for advice. I would like to put a usb where you can see an orange and white label with 170/105 on it to the left of the display screen. I have asked my Ktm dealer but they don't know. (They did put a dual usb on handlebars but it fouls the fuel cap and any tank bag). Does anyone know at all? I would also like to have a wired satnav. Any advice appreciated. Tom
I'm not really sure what you're asking.
Can it be done.. almost certainly.
I went a different route on my 1190. Are you any good at making up cables?
I put a relay (for switched 12 volts) and 5 volt psu from the relay under my seat and then ran the power cables up to the front, both going to small cable moulded sockets which can just be cable tied to the frame, or bars, or anywhere really.
If I have my phone holder/charger on the bike it plugs into the 5v one. If I have my Garmin on it plugs into the switched 12v one. The good thing is that I can also remove either if I'm not using them and the cables just took out of the way, and there's no need to cut holes in the dash area.
Hi, thanks for reply. Don't know whether you can see the twin usb on the handlebars but I would like to get rid of that and have it put where the sticker is.
Bit of a long story but...when I bought the bike I asked for a dual usb and the salesman (who has since left said it could be put there) but when I came to pick up the bike they had stuck the usb socket on the handlebars which is in the way. The dealers been ok but although he has researched it can't fit it where I would prefer (although I would think it probably can). So I'm looking round to see if anyones got any ideas. Also, importantly for me I would like them to do it because I don't want to cockup the electrics.
Hi. I recently purchased new 790R and am looking for advice. I would like to put a usb where you can see an orange and white label with 170/105 on it to the left of the display screen. I have asked my Ktm dealer but they don't know. (They did put a dual usb on handlebars but it fouls the fuel cap and any tank bag). Does anyone know at all? I would also like to have a wired satnav. Any advice appreciated. Tom View attachment 32188
On the road going KTM's that I have had there has always been an 'AC1' & 'AC2' 12 volt supply behind the headlight. One of them is switched with the ignition, the other is permanently fed. They draw 10 amps from memory, therefore ideal for USB, Nav or heated grips. Sounds like you need to change your dealer!
Thanks for your help. My dealers been pretty good at everything else, but yes have to say on this, not too impressed. I took it to another Ktm dealer. He said although he wasn't sure if it could be done, if I booked it in he would have a look. Again I don't think this is great. I would have to pay which might be for nothing. I'm surprised they don't seem to know.
I think I'll let them know what you said when I take it for its first service. I have to do 650 miles I think. Cheers
Hi Fozzy. Apologies, only just seen your message. I'm crap at computers. you got a 790r? Would you be able to tell me how you did it please?
Just got one of these, will wire it to ACC1 or maybe ACC2, plan on mounting it so I can use my phone as a video and a GPS but I don't go far off road so YMMV.
Discussion Starter #13
Hi. Don't know if everyone knows but on my bike there's a socket under rear seat specifically to plug in a usb accessory you can purchase from Ktm. Its the black socket on the right.
Regards
Tom
Discussion Starter #15
I got one of these, not fitted yet.
Hi Charlie. Yea, nice one. Like the idea of on/off switch and no need to worry about battery drain. Where u gonna fit it?
Tom
Discussion Starter #17
When I can be arsed to remove dash and dill a 32mm hole.
Where abouts exactly? Only I was thinking bout sticking it directly to the left of the display shown in my photo above where the orange and white sticker is. You probably know but its a black removable bit of plastic and you can access wires from headlamp. The fact your usb has an on/off switch means I'd be happy using the ACC1 (permanent live) supply wires for power. But will have to see whether the diameter will fit. Tom
Discussion Starter #18
Hi Charlie. Actually, what I might do is leave that space in case I wana mount lights on the front and have a think about either swapping the 12v 'cigarette lighter socket' for your usb or forget your usb altogether 😂...only I've ordered a usb from Ktm that plugs straight into the purpose made socket accessed under rear seat. Tom
Ive not measured it, looks like 32mm, standard as is 25 and 20. Personally Ive never used my cigarette lighter for anything other than USB, so I'll remove it probably but its handy to hide phone under seat when charging. I got two, one with dual usb and the one with switch which is waterproof. Main reason its got a volt display to keep and eye on R/R output.
1 - 19 of 19 Posts
