1 - 3 of 3 Posts
Hi guys,
Bought a KTM 450 2010 that came with supermoto 320mm rotor and extended brake bracket.
I'm now trying to fit the enduro wheel that mounts a 260mm rotor but can't seem to find the original brake bracket anywhere online.
Just the 320mm for supermoto or the 270mm one for the aftermarket floating rotor.
Any ideas where I can find this piece?
Thank you!
Hello & welcome
Unfortunately I am unable to help with your question, but I am sure someone will be along shortly to assist.
Hi any KTM 125cc upwards bracket from 2009 to 2020 will fit your bike. £95 from KTM dealer. Doc Wob has a new one for £65 but doesn't appear to have the mounting pins in the photo (be aware you can't buy these separately) Used brackets are on ebay regularly, worth a search. If you have the 24mm piston calliper (new shape) it won't fit the pre 09 mounting bracket. Bob.
1 - 3 of 3 Posts
