Hi,
I nearly had my bike (LC4 2006 Supermoto Prestige) stolen and the only problem I haven't yet been able to fix is the indicator issue. I found to day some damaged cabling and think this is most probably the cause.
I'll try and get a picture up and if someone could correctly identify the section of cabling, I think all I would need to do is buy a replacement.
Other than the indicators, the light on the control panel doesn't flash when they are engaged.
Hopefully I have correctly diagnosed the problem. If there are any helpful suggestions as to another cause then I'm all ears.
Thanks in advance :)
