1 - 2 of 2 Posts
Hello, just wondering why the exhaust rubber seal keep vibrating loose, I’ve put cable ties as tight as I can but still happening. I’m running a full Bills Pipe MX2 on the bike. Seems to be because of the vibration, I’ve ordered some O Rings for the front pipe as I know they need changing, could this be the factor?
Are you sure that its on the right way? One end has a smaller internal diameter (l cant remember which end does which but its obvious when you look).
Otherwise, it must be proberly worn or the pipe has an odd diameter.
IME, FMF are the best aftermarket fit on 2T's.
1 - 2 of 2 Posts
