1 - 4 of 4 Posts
Has anyone had problems with Bud Cylinder heads not sealing around the cylinder head bolts?
Searched the net to see if there are specific washers to use as the KTM ones seem too small and coolant just floods out as soon as you fill it up.
Tried 10 mm and 12 mm diameter copper washers but still leaks. It was fitted with 12 mm before and they sealed fine but just rebuilt the engine and it won't seal :hmh:
Any ideas anyone?
Hi NikNak
Tried that and with fibre washer, but because they have to be torqued it just spreads them out from under the washer. Going to try two washers under each one later to see if that works?
Thanks for the offer of the O-rings though, appreciated.
Emailed Judd Racing as they sell Bud Heads but no reply?
Pete
1 - 4 of 4 Posts
