1 - 10 of 10 Posts
Hello. I KTM SXF 450 2010. flowed fork. decided to dismantle. Oil poured out of the cartridge. poured oil into the plug. but did not understand how to pour oil into the cartridge and the plug. and how to disassemble the cartridge itself .. thanks in advance.
The problem is that I could catch, and poured oil from the cartridge opening hexagon. i dont take the fork cap apart. how much oil to pour into the cartridge and where?
Did you look at the link above?????
. Its a measured volume, no height like on the earlier forks.
any links? you can tell me manual for this fork to find? if not difficult. if there is no manual, could you show the pictures from pouring oil into the cartridge. and in what quantities. I read that to pour 195 ml. that right?
195mm on the cartridge (plug??) charge it to 1,8 bar pressure
385ml in the tubes, pour from the top BUT make sure the tubes are empty before you start filling!!
1 - 10 of 10 Posts
