hi thanks for all your replys still having the same problem too much air and oil on the pistion changed the crank case gasket but it looks like the crank seal has gone would this give me the problem that i am haveing the problem is the bike will not rev sounds like it is chokeing its self then found gear oil on the piston so could it be drawing air from the crank seal?????????????
thanks brad
