Well i posted on here a while back about starting issues, so since then i have replaced the battery with a new yuassa, had a service at hyside in romford with valve clearneces done
but since then it takes ages to start, not quiet firing up, i have to use the compression lever aswell, but hyside say this is not unusal , so i decided to get another starter motor, just fitted then the same problem, it will crank, crank crank, go to fire and trys to start then does not , this last for about 30sec to a minute, once its fired its a little lumpy for a few seconds then ok
this is only on first start up, if you turn off leave for a minute it will be fine and fire straight up ??
do you think its a fueling issue, any other ideas welcomed
phil
