Finally got to install the Lectron carb a couple of days ago and tested for first time today. Had to mess around a bit to get the correct amount of throttle free play but easy enough.
On the 2017 bikes you have to replace the throttle body and throttle cable (because KTM's new throttle body and cable is a very different) so what Lectron Fuel systems and also Slavens Racing does is put together a package for you which contains a Motion Pro Vortex throttle body, a Vortex throttle cable, the carb and a metering rod adjuster.
I also ordered a set of ODI Black half Waffle lock on grips as I wanted to keep the throttle grip the same as before (ODI Black Half Waffle Lock-on Handlebar Grips | ODI | FreestyleXtreme | United Kingdom)
Installation an absolute breeze. Everything just fits. I didn't make any adjustments to the carb whatsoever. Just put it on and went riding. Then adjusted the idle screw a bit. That's it.
The choke is on the 'wrong' side of the carb but as it happens on the new 2017 bike it's much easier to access from the other side now! Have a look at the pic below.
RESULT: I can honestly say the difference is night and day. The bike revs clean and crisp all the way through! No discernible hesitation or bog anywhere. I can now ride a gear higher and even then when you open the throttle it just pulls. It feels like the best jetted bike I have ever owned. Honestly, don't think any carb bike I have ever had felt this crisp and good. Best bit of money I think I have ever spent.
The carb has a unique feature in that the bowl overflow tube routes back into the carb so you never loose fuel, it gets re-used!
I am getting a tiny bit of splurge from the exhaust that I'll email them about to see if it's an issue but I don't think so. Also, I had to raise the idle a bit more to stop the engine from stalling on steep downhills - not an issue as it doesn't need raising so much that it makes it idle high.
