1 - 3 of 3 Posts
From the slave cylinder end of the pushrod, fitted a new seal just over a week ago, done about 100 ish miles no problems but today she spat the oil out big time, rear hoop and tail unit covered slippery stuff. I can only presume seal failure ?
To give you the complete picture I had the clutch out to do the oil pump drive gear, the pushrod did not want to pull out so I removed the slave and tapped it out, it leaked a bit on reassembly so I put a new seal in and all seemed fine till today.
Bit of a bummer as I fitted a throttle tamer this morning and was really getting into throwing it about with added confidence, any ideas what's going on ?
Got the bike stripped down this morning, nothing looks like it's been savaged by a Staffie ,apart from the seal as you have to destroy it to remove it, I'll put it down to premature failure/bad part
1 - 3 of 3 Posts
