Morning. Just wondering if my one has lowered their 1290S using this Mizu thing. It sits under the rear shock and lowered the bike 25-30 mil. Obs would need to drop the forks too. What’s your views, any issues?
Gear4 have done a few and reckon it’s good and although the bike stands taller it’s not so bad that stands need altered.
Yes I have fitted one to mine .dies drop the bike a bit but don't expect miracles.lowered the forks a few mm.uf you lower forks to much you lose the full lock cause of the stearing damper. Done over a 1000 miles now no issues
Thanks very much, when you say don’t expect miracles what do you mean exactly please. Does it actually drop an inch or one inch and a half ish? Does the bike still handle okay and did you need to shorten the sidestand?
Can’t decide wether to do this or get a HyperPro lowering spring.
Many thanks
It went from tipytoes to the balls off my feet.would love an other inch more but what man wouldn't .handling is exactly the same in my opinion.hope that helps
It does……thanks mate
Discussion Starter · #6 ·
Did you need to chop your sidestand?
