1 - 3 of 3 Posts
as the title says i have no spark at the plug i'm no amateur when it comes to bikes but electrics are a pain - changed plug no joy - changed suppressor cap no joy - so i started digging further back . Has the coil gone down ? possibly no idea how to check. However it has two wires on the coil a blue/white and a green earth , I assume the blue and white comes from the pick up unit and when i put the multimtere across this to earth i get a reading of -1 ? is this correct ? this reading doesn't change when i spin the engine on the electric start - anyone any ideas ? heeeeeeeeelp please
Gray
My Reality Check bounced
checked side switch, kill switch ignition eetc first? maybe stator or pickup?
when kill switch operated bike won't even turn over on starter so i assume that it's working fine - bike is in neutral with side stand up sat on a paddock stand - I'd thought it could be pickup that's not triggering the ecu to send a voltage to the coil ??? any help or suggestions are most welcome
thanks
gray
1 - 3 of 3 Posts
