Hi, I have an 06 400 EXC, due (list of excuses) it hasnt run for a couple of months so over the last two days I have checked the valves (only one intake needed minor tweek), cleaned spark plug and air filter.
It took ages to start but just as I was about to take the tank off again to check the plug it started.
I had the battery charging for three hours but no good what so ever but it starts easy on the kick start.
What is the downside if I dont change the battery ? other than having to kick everytime.
Is there a special tool to remove the front bolt from the valve cover nearest the frame ?
"What is the downside if I dont change the battery ? "
The only downsides I can see are that a) you will be carrying extra weight for no reason and b) you will probably need to buy a battery should you try to sell the bike
"Is there a special tool to remove the front bolt from the valve cover nearest the frame ? "
Not that I know of, I use a 8mm ring spanner
Dont buy a YTX5L-BS, get a YTZ7S-BS.
Its same physical size, but almost twice as powerful!
OK, it costs more...... but not a lot more ;)
