1 - 9 of 9 Posts
battery and connections are good,relay clicks when the starter button's pressed, but the starter motor doesn't kick in
shorting the relays connections with pliers does nothing
starts on a kick
i'm thinking my starter motor's the problem?
any ideas lads?
cheers
What have you done to check the battery? Have you tried measuring voltage as starter is pressed and not just when sat there.
And - Get +v feed straight to starter motor, if no joy, starter motor is lunched. Take s.m off, open it up, and if it smells like arson, get a new one.
As above. Batteries can be knackered dispite show ok voltage. It's when it needs to pull amps the voltage drops off . It only needs a few volts drop to not have enough to turn motor properly. Also as above take a wire from battery + and touch on motor connection. If earth is ok it should spin up. Remove and do the same to check for any mechanical issues.
hi -tech diagnostics this morning
matey banged starter housing with hammer and big screwdriver
while i pressed the magic button
starter turned over
ordered a new starter today as the original's got 400+ hrs.
gona not switch off on the next rides
or park on a hill
what gear do you bump-start in,i'm thinking 4th?
cheers
You could try pulling it apart to clean/check for a temp solution but it's most likely brushes but they can also be replaced.
try new brushes and clean the comutator....
Worth a shot now we are all about to have time on our hands.
1 - 9 of 9 Posts
