ive got an oil leak on my output shaft behind front sprocket so i bought all the seals and a new spacer bushing fitted them all and its still leaking :censored: any ideas as to what else could be causing it to leak any advice would be appreciated
have you put the front sprocket on the right way - it happened to me and th eoil leaked but the sprocket seemed fine untill i realized
Need to swap the O ring inside as well.
Is the washer dished properly? The dishing keeps the sprocket tight against the bearing, squeezing the O ring
changed the o ring at the same time mate might try changing the washer in case its not putting enough pressure on the o ring cheers
