Hello,
First of all greetings from the lowlands on the other side of the canal!
I've got a question. I'm in the process of buying a KTM RC8R from 2014 after getting my last(finally) real man drivers license.
I was looking at some powerparts and I was wondering if someone knows if there is a power commander for a '14's RC8R because I couldn't find any? The only ones I could find were power commanders for RC8's up until 2013.
Thanks in advance!:)
All you need is a power commander for twin spark ktm, I can't remember the model number but I can find it for you if needs be. However, I'd advise you to save a lil cash and find a dyno centre that are competent/comfortable doing it straight to your ecu. An ecu tune will. Have higher levels of adjustment, ignition timing being one as far as I am aware.
Sent from my SM-N950F using Tapatalk
Thanks for the reply!
If you could find it that would be really nice:) I will drive it stock for the first few months but maybe I will be buying a power commander anyway just to give it some more power;)
I’ve been looking into a power commander for my rc8-r but every ktm specialist I’ve spoken to and dyno technician have told me to stay clear of putting Power Commander on and get the ecu flashed get same or even better results than PC and a lot my torque in mid range.
