1 - 3 of 3 Posts
Hello All, my 1st KTM, and my 1st bike with semi active suspension.
I have a Preload Failure after I changed the setting from Single to Two with Luggage, while I was sitting on the bike, No pillion, it flasshed the 2 persons logo then went solid, then turned on the waring light, so i thought i would change it back and nothing happened. now i have got the warning light an warning message flashing at me randomly.
I refered to the manual, and you are supposed to set the preload with none on the bike, and on the central stand, so i tried that, and still the warning light is on. I watch a few Youtube video's but none of the fixed my issue.
Any and all advice is welcomed.
Oh dear. Hope its fixable.
When the guy serviced my rear shock, although it was on a 990, I mentioned that the pre load was seized. He warned me of impending doom and cost, as the thread on the preload is very fine and easily damaged, with grit, mud and road grime, especially if off roaded. Luckily he was able to free it, easily.
Good luck. I expect it's the motor or something simple.
Thanks DoubleL, ill get my local Bike Mechanic to look at it 1st, then if neeed to the main dealer.
1 - 3 of 3 Posts
