FOR SALE
LEYLAND ROADRUNNER E REG.
Box lorry converted to motor home, with electric tail lift, used for motorcycle racing and will carry three bikes, would also suit carts or quads. The lorry is 7 meters/23ft long and is 3190mm/10-6ft high. Tested to 7/4/2011, taxed to 31/9/10 and will be SORNed, as it will be dry stored over the winter. Oil and all filters have been changed previous to test in March and had change of clutch last August. The body is long and high. All tyres are in good condition and has been recently repainted in white with blue bumpers, front grille, mirror arms and mud guards. There are two spare wheels with good tyres, and has spot lights and air horns fitted. CD player with MP3 and WMA using SD card, USB and AUX connected to Fusion components and tweeters with Blue tooth hands free. It has been cut through from the cab to the living area in the front of the body.
The living area measures 2370mm long by 2170mm wide. It is fully insulated finished with tongue and groove walls and ceiling, tiled above sink and cooker area. It has bench seats on three sides which can be used for beds with storage underneath, it has a 12 volt light and is wired for 240 volt hook up and is fitted out with lights, microwave, 19 inch flat screen T.V. with built in free view, JVC digital cinema system with surround sound, it also has a covered sink with pump, double ring gas hob and fridge built in. The side door and steps were taken from a prison lorry. There is extra storage above the side window and a single bunk above the seats. There is a night heater fitted but has never been used.
The load area measures 2438mm long by 2250mm wide. It will carry three bikes, but is only used for two at present. It is fitted with front wheel chocks, lashing rings on floor, load-loc rails on both sides, high level shelves, wired with 12 volt light and 240 volt 6ft fluorescent with 2 x 2 gang sockets, powder fire extinguisher.
Also comes with free standing heavy duty 10ft by 10ft marquee, white roof with blue and white striped sides used as awning, has enough room for 2 bikes.
Would make a good horse lorry if tail lift was removed and back door was changed.
PM me for photo's.
Truck currently located in N. Ireland.
Any viewing welcome.
