Hi can any1 tell me how much to tighten the rear sproket bolts in NM or lb/ft torgue...
badboy · Registered Joined Oct 21, 2009 · 10 Posts Discussion Starter • #1 • Aug 23, 2010 Hi can any1 tell me how much to tighten the rear sproket bolts in NM or lb/ft torgue...
keith-iow · Registered Joined May 4, 2006 · 7,637 Posts #2 • Aug 23, 2010 dont know the exact settings.......... but fookin tight so this dont happen
Jigger · Registered Joined Aug 2, 2008 · 2,440 Posts #3 • Aug 23, 2010 Manual for 2005 exc states loctite 243 & 35 NM
KevInYorks · Premium Member Joined Aug 19, 2006 · 31,545 Posts #4 • Aug 23, 2010 You MUST tighten the nuts, not the bolts. Use blue (nut) loctite and tighten the nuts as tight as you can while holding the screw.
badboy · Registered Joined Oct 21, 2009 · 10 Posts Discussion Starter • #5 • Aug 23, 2010 Thanks 4 that job done !!!
