1 - 20 of 64 Posts
I thought I'd miss a rev counter too coming off a GSX-R but to be honest, after the scream of a ride I had today, I can honestly say I don't see the need.
I'd like a tacho, but probably just for curiosity value. those LCD units look pretty swish.
For me it was a case of wanting one rather than needing one. I've never owned a bike, or car for that matter, without one.
It's not a difficult job, especially when you have help from someone who's done it before (Pretender :))
Bill
Ex 9fiddy sm'er
It's just a shame the handy little triangular shaped indent on the tacho can't be utilised better. You know what I mean, like a green to red increasing light from bottom to top like they have on race cars..
Bill
Hi
Can you give me an idea of how you did it and where you got the tacho from
Kind regards
MArk
Hi
Kind regards
MArk
The tach is made by Nova MMB in Germany
http://www.nova-mmb.com/
also supplied by
http://www.louis.de/
search for Drehzahlmesser, German for tacho.
The tacho has lots of options for face/surround/LED colour etc. but I used the the 48 mm 0-12,000 rpm variant.
For power the tacho has seperate connections available for tacho power and for the LED illumination. I wired these two together to ACC2 which is the accessory circuit on the 950SM wired to the ignition, buried in the loom in the headlamp mask.
Sensing is via a pin in the bikes ECU, which is located underneath the tank, in the frame fold just behind the headstock that is normally screened by 2 pieces of black plastic. You'll need to solder a female pin onto the end of the sensing cable and insert it into the ECU connector to make the connection.
Space wise the area in the headlight mask behind where I've mounted mine is quite busy. You have to trim down the bolt and nut that hold on the rhs indicator, and reposition a bracket that holds a few pieces of wiring loom. Nothing too tricky but time consuming.
The hole in the dash was cut with a tank cutter like this
http://www.tool-up.co.uk/shop/diy/PRI400.html?id=Kf3K5zgh
below the size of the tach, then taken out with a dremel until the tacho was a tight fit. Then I hot glued it in.
Bill
I think one of these gives enough of information about revs. When yours riding mode is relaxed it doesn't matter , but when you speed up it's important to keep it in the specific rev range.And it looks cool:smokin:.Photos are from net, not my bikes:D
Yeah I've got something similar. Its alright, works well,...but I'd just prefer a tach for some reason. :confused:
also supplied by
Bill
Bill,
I've been looking at the MMB tacho wiring. This may sound daft but when connecting the tacho to the ECU which connection is it, postive input pulse (green wire) or negative (white wire)?
Thanks.
David.
Bill,
Thanks.
David.
I would have thought you could avoid the ecu and just hook it up to the rear ignition coil.
I have this
Lets hope the 08 950sm has a rev counter
What on earth for? :confused:
It's gotta make more sense to use your ears to listen for when to change gear, and keep your eyes free for spotting stuff that's important to steer around.
If you're still at the stage where you need a rev counter to know when you need to change gear, then mebbe you're just not yet ready for a fairly powerful bike like a 950....... :burp: :D
:rolleyes:
I dont need one but last time i did a track day at croft, they were not gonna let me on track coz i did,nt have one, they need it for the noisey can test or summit, luckily my bike is standard so i got away with it but am modding my bike for next year coz am loving takin it on track, ooohhhhhhhh what a kerfuffle!
If you have never ridden a bike with one, you won,t understand. :burnout:
1 - 20 of 64 Posts
