(EDIT 24Jan2015....more questions below!)
I've had a good look at the maps available both on the TuneECU website and the extensive list started by kevxtx on the ktmsmt forum but can't find anything suitable (maybe I should say I couldn't see anything suitable!).....for one thing I don't really want to have to start DIY tweeking maps.
Anyone able to point me in the right direction of a suitable map? I intend to have the bike set up on a Dyno (CJS Racing) but Chris won't be able to fit me in for a few weeks so I need a decent map (decent = bike running reasonably well and certainly not too lean or anything potentially risky like that) to upload with TuneECU meantime.
I've sussed uploading maps with TuneECU.
# 2012 UK 990 SMT
# Rottweiler Intake Kit (OE airbox completely removed i.e. lower section ditched not just the 'lid')
# SAS hardware removed (blanking plates fitted and SAS unchecked via TuneECU)
# Secondary butterflies in/present (leaving them in [fttb anyway] on Chris's advice)
# LeoVince LV1 INOX EVOII (LV8414) cans (baffles in) inc 'Y' pipe
In browsing around came across a couple of bits of info......which raise more questions for me! :-O
(5) .......tell me more please......2nd/3rd gear limiter?
15 minute idle - anybody explain to me what's going on with that - time for the ECU to 're learn' bike setup?.........so if the ECU has been reprogrammed/remapped...why? What is the actual process that's going on?
THANKS!
# 2012 UK 990 SMT
(3) .......sounds interesting.................................
1 Is SAI SAS? YES
2 Should i deactivate 02 sensor? YES
3. whats 2nd Throttle? Its the upper set of throttle plates. I have a map that limits them to 30% shut, makes the throttle smoother.
4.Idle speed control ? Tickover control, it ticks over faster when its cold.
5.EPC Turn off? Yes, that the 2nd and 3rd gear limiter.
Secondary flies set to 100% across the board......different advice to above - thoughts/opinions please.........
Put 2nd flies 100% open at all times and dont unheck it (works really well I think)
Then put the map into you bike, when its done, turn the ignitionkey off, disconnect PC, start the bike and let it stand on idle for 15 minutes WHITOUT touching ANYTHING.
Then its done![]()
THANKS!
