Sealing the tyre to the rim with a Tubeliss system
11K views 43 replies 15 participants last post by  steveman
Sorry if this has been covered before but I never have any luck with the search function!
My rear tyre is loosing air slowly (but annoyingly) from between the tyre and the rim in many places, I haven't tried re-seating the tyre or cleaning up the rim yet but I was wondering what you guys used as a sealant. I have been fitting the tyres with diluted washing up liquid but was wondering whether a proper tyre soap would be better because it would fill in any small gaps between the tyre and rim.
#43 ·
Update from my side.
I decided to go with slime, I ran a smear of the stuff on both sides of the red liner, I then fitted the tyre and ran another smear on both beads of the tyre, I did not use very much, just enough to make the red liner slippy and the tyre's beads slippy. I inflated the bladder to 100 PSI and tyre to 30 PSI, I tested for leaks using a container full of water and it's totally sealed!
I must admit that I was not happy with the thought of water slopping around inside my wheel, using this method there was no water involved at all apart from testing for leaks.
Reactions: steveman
