1 - 20 of 50 Posts
My 250 exc is bogging low revs and when pulling away..
Checked loads of stuff today;
Spark plug: br7eix
Main jet: 165
Pilot jet: 35
Needle position: 3/middle.
Air/fuel screw: 1.75 turns..
Not sure what else to check 馃
have you tried altering the air screw?
What needles ? the jets are lean
up the pilot to 40 and the main to 168
Itll be stronger then
Maybe go to clip 2 if its too much
Yeah I eventually saw the post it鈥檚 difficult to see on the iphone with this shite new look
I think your lean try a bigger pilot 1st
Yeah
Pull your plug if should give u an idea of how the engines running also check your exhaust no leaks from the seal etc while your waiting for your jets
Let me know what your needle is and what jets you have and i鈥檒l tell you what to try
what needle is actually in the carb?
I wonder if it always bogged or if it just started. If it just started and was fine before I doubt it's the needle...
Discussion Starter #20
Only just brought it mate and it's a different needle to standard and the one in the manual suggested for it
1 - 20 of 50 Posts
